93 s-10 blazer transfer case opperation
Old 08-29-03, 12:16 PM
james19501967
Smile 93 s-10 blazer transfer case opperation
Thanks all, I got the correct answer this afternoon.
For those that might need to know the procedure is as follows :
Push the rocker switch to what ever position 4 hi or 4 low and as long as everything is working right the computer and selector will engauge the selected range. To go back to 2 hi select the same range again and release the switch to the spring loaded center position and in a short time the system will resume 2 wheel high opperation.
Thanks again for all the imput.
I am looking fore the instructions for turning on and off the four wheele drive function on a 93 chevrolet S-10 Blazer 4X4 with 4.3L v6, auto trans and I believe a 233 transfer case. Are you supposed to push and hold the selector switch until the indicator light lights and if so then how do you turn it off?
Thanks in advance Jim
Old 08-29-03, 12:54 PM
Joe_F
What does the owner's manual have to say?
If it's missing, get a new one from Ebay or www.helminc.com
Old 08-29-03, 01:53 PM
U WOULD DEPRESS THE 2WD BUTTON TO SHIFT FROM 4WD TO 2WD.
Old 08-29-03, 01:54 PM
U WOULD DEPRESS THE BUTTON FOR WHATEVER MODE U WISHED TO BE IN!
