09-01-03, 04:59 PM
brain
'92' cougar frnt brakes locked up
I have a 92cougar that I recently replaced the front roters and pads, shortly thereafter the front brakes locked up. I replaced the master cylinder,( in the process the front brakes disengaged), I followed all manufactuers instructions, as soon as I started to move the car they locked up again, I bled all the lines and this did not help,there is no ABS system on this car. Somebody please give me a good solution to my problem. brain
09-01-03, 05:44 PM
Joe_F
You likely have bad rubber flex hoses going to your calipers. Throw them out, replace them and rebleed your system. Failing that, stuck calipers.
