Air Flow Control
Old 09-01-03, 10:43 PM
Air Flow Control
My 2000 Ranger XL only blows out through the defroster ducts.No matter what i turn the "Mode Selector Control" to it blows out the defroster ducts. No air will come out the instrument panel or floor ducts.Is this a DIY project?
Old 09-02-03, 02:54 AM
Sounds like a loss of vacuum. Look for a broken or cracked vacuum line on the engine for the heater A/C system.
For saftey reasons when the system losses vacuum it goes to full hot out the defrost duct.
Larry
Old 09-02-03, 06:39 AM
Joe_F
I agree with Larry.
Old 09-02-03, 10:50 AM
Since I don't have A/C I have it turned to full cool and it does seem to be cool not hot, but won't come out any of the other ducts.
Old 09-02-03, 12:15 PM
Joe_F
Still a vacuum problem based on the info. here.
Old 09-02-03, 10:58 PM
Okay how about this,today when i started it up for work it was set on panel ducts and it blew through defrost for about a minute then all of a sudden it kick into the panel ducts and ran through them until i shut off the engine.Then when i started it back up it wouldn't kick off defrost for the rest of night.
Old 09-02-03, 11:00 PM
mike from nj
still sounds like low vacuum, trace out the vac hose from the engine to the firewall, see if anything is leaking or cracked
Old 09-03-03, 06:40 PM
msargent's Avatar
I agree with the other gentlemen.. Sounds like a vacuum problem!
After you open the hood, on the left side of the engine compartment (left as you look at the engine.) you'll see the case for the heatercore and evaporator..Usually, the vacumm line and vacuum canister for the vent control is mounted on the top of the case..Black, and looks like a mini goodyear blimp in shape..You can trace the vacuum lines each way from there...Also, when you're inside the truck, windows up, radio off, blower on it's lowest setting, can you hear any kind of hissing noice from the area of the vent control knobs/switch? I've seen vacuum leaks there cause the same problems...
