'92' cougar's stuck brakes
Old 09-02-03, 06:06 AM
brain
To Joe F, Please excuse my ignorance, your answer was along the same line of thought that I had but since all four brakes are independant of each other then what would cause both front brakes/calipers to lock up at the same time or both hoses to go bad at the same time? brain
Old 09-02-03, 07:37 AM
Joe_F
Again,
The hoses clog up with debris and act like check valves. In this manner it will lock up the caliper. They rot from the inside out and should be changed periodically.
I'd start there and rebleed. See where that nets you. Any parts store stocks those hoses.
