brake lights don't work when headlamps on
SMTodd's Avatar
09-02-03, 04:38 PM   #1
SMTodd
My daughter's 1991 eagle summit: the brake lights don't work when you turn on the headlights. They work (somewhat dimly) when you turn just the parking lights on, and fairly normal when headlamps and parking lights are off. All fuses are fine. Any ideas?
Steven
mike from nj's Avatar
09-02-03, 10:05 PM   #2
mike from nj
is this a mitsubishi type car--renamed
from your description, you have lost the ground to the rear sockets--common on most cars/trucks.
take out the rear taillight housings, and look closely at the gound wires. sometimes the ground breaks inside the socket, you would need a toothpick to permanently wedge it back together. some cars have a 'ribbon' type wiring that can break. if this car is like a colt, i seem to remember tightening loose ground wires in the rear somewhere(it's been a while).
you can verify this by temporarily substituting a ground wire and seeing if everything works, then you should be able to take it from there
let us know
Joe_F's Avatar
09-03-03, 03:56 AM   #3
Joe_F
Mike:
The Summit is an Eagle product which is a Mitsu rip off in disguise, much like the Colt was in years past.
Most of these cars used some kind of metallic socket and the grounds turn to dust as you stated. Also, water in the lenses will cause corrosion and problems. I've been behind many a Japanese car with a leaky taillight. LOL. (can see the water sloshing around in there)
SMTodd's Avatar
09-11-03, 02:35 PM   #4
SMTodd
Stop lights didn't work when headlamps on
Thanks all for the advice - it was a ground problem that I wouldn't have found on my own. I bypassed the existing ground connection and everything worked.
09-11-03, 08:40 PM   #5
mike from nj
thanks for writing back and letting us know, many others benefit from your reply too
Joe_F's Avatar
09-12-03, 04:03 AM   #6
Joe_F
Good for you and good job.
