chev lumina 1996 alternater
Old 09-04-03, 04:38 PM
kenny1996
I have not changed an alternater in 30 years. anything different now with this 1996 chev lumina? Thanks for your help. Kenny
Old 09-04-03, 05:48 PM
msargent's Avatar
Other than a change from standard bolts and nuts to metric, it's pretty much the same..
bottom bolt should be a 15mm, top bolt should be a 13mm, the output wire should be a 10mm, filed wire is a plastic connector.
They do hide a bolt on the "back" side of the alternator..(sometimes there's a plastic steering line bracket covering the bolt..)
Old 09-05-03, 05:15 AM
kenny1996
msargent thank you
thanks again
Old 09-05-03, 05:57 AM
Joe_F
Arrow
Agree with MSA.
Check autolibrary.org below for any R&R instructions they may have.
