Power Sliding Door
Old 09-10-03, 09:42 PM
campbellguy
Power Sliding Door
I own a 1997 pontiac transport ext. I have done all recalls on sliding door. My first problem is that when vehicule is on incline ,the sliding door opens .And now my second problem is the last that the sliding door opened , I pushed on the door and it made a gear noise. Now it won't worked at all. The fuse is good,I have no 12 volt at the motor.I would appreciate acircuit diagram in order to understand how it workes because I ain't going to the dealer again.Thank You
Old 09-10-03, 10:23 PM
Joe_F
Best bet for a schematic is either a manual for the library or a $25 Alldata.com subscription in this case.
See if Alldata.com has additional recalls on this vehicle/problem.
Old 09-11-03, 12:11 AM
mike from nj
make sure whoever sits near that door wears their seatbelt until you're positive it's fixed!! they have been known to open while driving.
when you do figure it out, i (me) would be buying the parts from a dealer, not shopping for the best price, the dealer usually has the most updated parts that might not fail so quickly the next time vs. replacing it with the same part that is only as good as the old one.
something to think about
Old 09-11-03, 02:56 PM
B
POwer sliding doors are very complicated, even for a dealership tech, you might not like it, but you will probably have to go to one...
Old 09-11-03, 08:05 PM
campbellguy
complicated
All I ask for is a circuit diagram,not if its too complicated or not.Let me handle that part.Thank You
Old 09-11-03, 08:08 PM
Joe_F
Arrow
See my original reply for sources of diagrams.
Old 09-12-03, 01:26 PM
B
Old 09-12-03, 04:51 PM
D
I'll send you the diagrams but they are just the tip of the iceberg.As stated these doors are a PITA.a wiring diagram may not be all you need,there are specific steps and procedures that need to be followed to diagnose it properly.To much to post and attempt to explain here.
Old 09-20-03, 06:04 PM
campbellguy
sliding door
Thanks for the wiring diagram,I also need steps and procedure for troubleshooting,also location of modules woulb be nice. Sorry if I send this message twice,my connection keeps failing
