Speedometer
fishinfool's Avatar
09-12-03, 11:20 AM   #1
fishinfool
Speedometer
1988 GMC JIMMY 2.8l. Speedometer only works when the truck warms to normal temp. What could be the cause?
Joe_F's Avatar
09-12-03, 12:45 PM   #2
Joe_F
Bad speed sensor, old tired cable, hardened grease in the cable or speedo head.
Clean/inspect/test.
bigguy05641's Avatar
09-12-03, 01:22 PM   #3
AH YES SPEEDO CABLES, THE GOOD OLD DAYS.
KNOWING IF THE CABLE IS TURNING UPON FAILURE WOULD BE A GOOD THING. IF NOT, NOT SURE IF THIS IS 2WD OR 4WD, BUT THE TEETH ON THE DRIVEN GEAR IN EITHER THE TRANSMISSION OR THE TRANSFER CASE COULD BE WORN..
