Problem on my 92 Honda Accord
joemac88's Avatar
09-13-03, 12:18 PM   #1
joemac88
Problem on my 92 Honda Accord. While driving I note the TACH needle "bumping/ jumping" up intermittently and drops to 0, then the needle quickly jumps/ pops up some times it dies. After starting and restarting the car over and over for maybe a 1/2 dozen times, it eventually will not run at all. It turns over, but will not engage and run.
Symptoms include:
·Poor starting when very often when warm.
·In extreme cases engine could cut out / and will sometimes restart if left for a while. Sometimes it may not start at all.
·An erratic rev counter
NOTES: I've changed the Main Relay, new cap and rotor, plugs and wires.
I think it is the Ignition Igniter Module
Joe_F's Avatar
09-13-03, 02:58 PM   #2
Joe_F
More likely to be a vacuum leak, a dirty throttle body or a bad idle air control valve than anything else.
Have a look.
car nut's Avatar
09-14-03, 08:38 AM   #3
If the engine misses or cuts out when the tach acts up it sounds like a short in the ingition system. You may be right about the ignitor.
davo's Avatar
09-14-03, 03:39 PM   #4
If it still will start listen for a tapping/clicking type noise from the distributor,if not see if you can pull codes.If you have a crank angle sensor code or hear the tapping I'd place my money on a rebuilt distributor.
joemac88's Avatar
09-17-03, 08:16 AM   #5
joemac88
going to look at this night.
If it is the ignitor, do I have to take apart the whole distributor or I think I read some how there is a short cut for replacing the Ignitor with taking apart the distributor...
Thanks
car nut's Avatar
09-17-03, 07:59 PM   #6
I have the factory manual for a 91 I suspect they may be the same but I don't know for sure. I could copy & fax to you if you want.
