ignition timing 98 2.0L ford
rcg's Avatar
09-14-03, 10:30 AM   #1
rcg
I have a 98 ford contour w/ 2.0 engine. reciently I had to change the cam drive belt and in the process got a shop towel cought in the ignition trigger wheel pressed on the front cam (I put the rag over the top of the engine when I turned the engine over so oil wouldnt go all over and in it went). I tapped it so it back so it runs but, now the engine runs hot and actually seems to be getting hotter as time goes on. there must be a procedure to align the ignition trigger wheel on the cam. I guess I should mention the front cam(where the trigger wheel is has a spring loaded pulley on the drive end. any help is GREATLY appreciated. RCG
Joe_F's Avatar
09-14-03, 11:31 AM   #2
Joe_F
Check autolibrary.org below. Failing that, what does your service manual have to say?
billys68ss's Avatar
WV
09-14-03, 07:21 PM   #3
Sounds to me like you have a NEW problem and not necessarily related to the rag issue. I dont see how the timing wheel being even the slightest bit out of alignment, although all that is going to do is change your timing angle, will cause it to overheat. Check your cooling system out thoroughly. How does it run? Good? Rough?
Billy
