Coolant Temp
Old 09-14-03, 05:57 PM
jeff moralez
Coolant Temp
Found out I don't have a bad sensor I replaced it and the guage is also not bad so what else could it be.
Old 09-14-03, 09:24 PM
mike from nj
keep your posts together or it's going to get confusing.
you should have two sensors
a 1 wire sensor for the gauge
a 2 wire sensor for the computer
which did you replace
Old 09-15-03, 07:16 AM
jeff moralez
The 2 wire sensor. I cant seem to locate the other sensor(1wire)
Thanks.
Old 09-15-03, 07:34 AM
Joe_F
What type of car are we talking about????
Old 09-15-03, 11:07 AM
jeff moralez
Working on a 1995 beauville 3/4 ton van . 350 Just cant get the temp gauge to work. Checked gauge with new and the sensor next to the thermostat housing. Both show good.
Thanks for the interest.
Old 09-15-03, 11:19 AM
Joe_F
Make sure you are changing the right part! Typically there is a sender for the gauge and a coolant temperature sensor.
Have the dealer point out the right part for you on their parts microfilm.
Old 09-15-03, 08:34 PM
billys68ss's Avatar
The temp sender for the gage is located in the cylinder head most likely on the right side behind the exhaust manifold.
Following is the test procedure for checking the sender and gage:
TEST
Disconnect the engine coolant temp sender connector. Ground the dark green wire at engien coolant temp sender connector.
RESULT
Temp gage indicates HOT
ACTION
Repair or replace temp sender
RESULT
Temp gage does not indicate hot
ACTION
Locate and repair open in DK GRN wire if wire is good replace temp gage.
Hope this helps ya,
Billy
