spit and sputter
Old 09-15-03, 04:16 PM
HOTWINGMAN
spit and sputter
I have a 1990 Chevy Lumina APV minivan with a v6. At idle the engine sounds really rough and at acceleration there is hesitation. It runs rough till up to speed then runs fine.
The check engine soon light comes and goes. Changed plugs and also changed the air temp control module on carb. cover.
Any ideas before I take it to the shop. Thanks for the help.
Old 09-15-03, 04:19 PM
How are the plug wires?
Old 09-15-03, 04:24 PM
HOTWINGMAN
sorry about that--changed plug wires too
Old 09-15-03, 06:57 PM
billys68ss's Avatar
Have you put a scan tool on it to see if there are any stored codes? This would be the first place to start.
Hope this helps ya,
Billy
Old 09-15-03, 08:40 PM
D
Sounds like MAP Sensor vacuum leaking but could be a number of things. Go to AutoZone and they'll read your codes for free. You may want to post reading before you start buying parts. A lot of these sensors affect each other's performance and coding. 1990 ECM trouble codes are not nearly as detailed as the newer autos.
Old 09-16-03, 03:55 AM
Joe_F
Thumbs up
All posters are correct.
Start with my "The Basics" below,and using autolibrary to guide you (If you don't have a shop manual and you should....) to test parts before throwing more parts at the problem (which won't do anything but drain your wallet and leave you with a still broken vehicle).
Pull your codes first as Billy said and we'll go from there.
Old 10-05-03, 07:28 AM
HOTWINGMAN
problem solved
Took the van to the shop--problem was the EGR sensor. Thanks for the advice everyone. Van runs like a dream again.
Old 10-05-03, 07:42 AM
Joe_F
Glad it's fixed.
