Intermittent Speedometer Troubles
Old 09-19-03, 06:52 AM
1993 Isuzu Rodeo
Engine: 3.2L V6 Code RLU
Automatic Trans: Code RMQ
4 Door
Intermittent speedometer
Periodically, the speedo quits working. That is, it says 0 even if I'm on the highway moving at a high rate of speed. Sometimes it does not work the first few minutes of driving. It also seems that I have up get up to 42mph and then it "kicks" in. But this isn't always, just sometimes. It happens sometimes 3 or more times a day and then might be fine for 1-2 weeks. Does not seem to matter if the vehicle is hot or not.
The speed sensor was replaced but the problem continued. Next, they replaced the speed gear. I still have the problem.
This damn thing has cost me nearly $400 and it still does not work. I'm tired of funding these shops retirement accounts.
Old 09-19-03, 07:17 AM
Joe_F
Time to find a shop that will solve the problem....
Possibly a bad speedo head, but that's rare. Sounds like someone missed something along the way.
I'd be back at the shop asking for a refund if $400 worth of parts has not fixed the problem.
Check alldata.com for any bulletins on this specific issue.
Old 09-19-03, 07:35 AM
Joe_F
Arrow Ding, ding, ding, we have a bulletin
There is a bulletin from Isuzu on an inoperative speedometer. I sugget you check it out with a COMPETENT Isuzu dealer:
http://alldata.com/TSB/29/93290915.html
