Alternator belt screams
Quark's Avatar
GA
09-20-03, 07:57 PM   #1
Hi, my 90 Geo Tracker was screaming...so I knew to tighten the alternator belt. Now it screams when I first crank it, for about 5 seconds then stops. The belt is tight ( with a really little amount of play). Should I just tighten it as tight as I can? Or can you make it too tight?
Thanks
Joe_F's Avatar
09-20-03, 08:02 PM   #2
Joe_F
Sounds like the belt is wasted.
If it's over 4 years old, throw it out and replace it with a new one.
Belts and hoses should be changed every 4 years on the dot. Use good quality belts like Gates and Dayco.
michael van's Avatar
TX
09-21-03, 03:12 AM   #3
no good
Just like Joe said belt is wasted it has streched beyond limits get a new one get a quality one like Gates.
dirty dan's Avatar
LA
09-21-03, 07:19 AM   #4
Good advice above...also, do not tighten your belt too much or you will ruin your alternator's bearings.
Hirsch's Avatar
09-21-03, 07:48 AM   #5
You might also want to check for spraying oil and antifreeze, since they can cause the belt to squeak too.
Quark's Avatar
GA
10-02-03, 06:16 AM   #6
Thanks guys. The belt is definitely older than 4 years, so I'll toss it. But I just looked at the alternator and there is oil on it, Thanks Hirsch. The only thing I can see over there is the dipstick. I would assume that I would need to try to patch that up B4 I put another belt on. Any suggestions?
TX
10-02-03, 06:25 AM   #7
dipstick
Some dipsticks have an O ring on the bottom of the tube that the dip stick goes into.I dont know if Geo is like that but Toyota is.This O ring leaks and should be replaced.
Joe_F's Avatar
10-02-03, 06:43 AM   #8
Joe_F
The oil is probably coming from somewhere else and being thrown about by the belts.
Change the oil and filter, gunk the engine and then see if you can find the leak.
