Funky window switch problem
Old 09-21-03, 06:58 PM
Talking about my 1992 Bonneville on another thread reminded me of a strange little problem I'm having. I hope someone here can help.
I can roll down the passenger side window with the master switch, but I can't roll it up. The passenger side switch rolls it up but not down.
So do I have two bad (or half-bad) switches, or is some other wiring issue the likely cause of this?
Thanks in advance!
Old 09-22-03, 09:42 AM
U MIGHT HAVE A BAD SWITCH, BUT FIRST LOOK INTO THE CONDUIT WHERE THE WIRING HARNESS GOES FROM THE BODY INTO THE DOOR, AND LOOK FOR BROKEN WIRES. AN OLD RIG LIKE THAT IS PROBABLY WHERE U WILL FIND THE PROBLEM. PULL THE BELLOWS AWAY FROM THE DOOR AND THE BODY TO SEE THE WIRING.
Old 09-22-03, 09:49 AM
darrell McCoy
If that has the express window, you may have a bad module inside drivers door. Water has a way of getting into it. Should be about the size of a pack of smokes. Usually black plastic.
