Mercury Cougar XR7 1996
Old 09-22-03, 03:39 AM
thickey1
Mercury Cougar XR7 1996 Have a 4.6 litre V8 with check engine light comeing on. This happened just after the engine was degreased and hi pressure washed. The car runs rough for a while like a car would run when there is water in the gas tank then runs fine after warms up. Still have check engine light on
Thanks in advance,
Old 09-22-03, 04:08 AM
billys68ss's Avatar
Put a scanner on it and find out what the codes are. This will narrow your search. You may have knocked a vacuum line or electrical connector off. Worse case, you broke or damaged something. Let us know what your codes are.
Billy
Old 09-22-03, 08:25 AM
Sounds like wires are wet, most likely water in the spark plug holes.
Larry
Old 09-22-03, 09:58 AM
darrell McCoy
I'd drive it a while, then check codes and reset light, will probably be OK. Pressure washing engines with electronic stuff is bad business.
Old 09-22-03, 07:00 PM
Joe_F
All are correct.
Tip: No need to steam clean an engine like this. Not a show car and doing so does more harm than good for the everyday car. Leave it be .
