oldsmobile bravada worth buying?
mudcat24's Avatar
OH
09-28-03, 01:47 PM   #1
im looking at a 1994 bravada with 107000 miles very good condition,nothing i can find wrong. im wondering if there is a bad history with this vehicle or any problem i should beaware of?
mudcat24's Avatar
OH
09-28-03, 01:48 PM   #2
they are asking $3400 for it if this helps on your replies
darrell McCoy's Avatar
09-28-03, 02:16 PM   #3
darrell McCoy
If you like the veh, and can find no major problems, the price is not that far off the wall. Sounds about right on mileage. Might want to take a look at alldata.
Joe_F's Avatar
09-28-03, 03:10 PM   #4
Joe_F
This vehicle is nothing more than a gussied up S,T Series Blazer/Jimmy (actually a T series because it's 4WD), so whatever's common for those, same as this.
Suggest you have the vehicle looked at by a professional mechanic and split the cost with the current owner so you don't overlook something.
bigguy05641's Avatar
09-29-03, 07:02 AM   #5
THIS VEHICLE HAS BEEN AROUND AWHILE.....NOT A BAD RIG.
LET'S SEE...TORSION BAR MOUNTS, CV BOOTS, EXHAUST SYSTEMS, EGR VALVES, OCCASIONAL TRANSMISSIONS. HAVE SOMEBODY TAKE A LOOK AT THOSE ITEMS.
Joe_F's Avatar
09-29-03, 08:07 AM   #6
Joe_F
1994 is probably a throttle body 4.3 vin code Z engine, so it's also very simple.
A Chevy V8 with 2 cylinders missing .
09-29-03, 08:32 AM   #7
AU CONTRAIRE JOE, I'D SAY IT HAS THE W MOTOR.
OH YEAH BETTER ADD THEY HAD INJECTOR PROBS ALSO.
THE DREADED OCTOPUS.
Joe_F's Avatar
09-29-03, 09:31 AM   #8
Joe_F
True, could be either I think? I can't recall when they did the switch.
I know the S,T series (the whole magilla) had both the 4.3Z and the 4.3W from what I remember.
The W motor came on later as standard equipment on the P/U.
The truck parts catalogs/engine charts are pretty willy nilly with engine/transmission charts. The cars are pretty good.
