heater/ac problems
Old 09-30-03, 03:22 PM
ohioman31
Question heater/ac problems
I HAVE A 94 INTREPID AND THE BLOWER BLOWS ALL THE TIME UNLESS I TAKE THE FUSE OUT. THE HEAD ON IT WORKS SOMETIMES AND IT ONLY BLOWS HEAT
Old 09-30-03, 11:06 PM
mike from nj
if it is all digital and with temperature control in degrees, it sounds like the control head(94 intrepid), take it out and verify proper power supply and ground, the module is also the face plate and switches, one part controls everything.
i copied and pasted this from the other thread
Old 10-01-03, 04:03 AM
Joe_F
Thumbs up
Yup, agree. Seems to be common in these from what I have seen.
Old 10-01-03, 04:51 AM
ohioman31
THANKS
I WILL CHECK FOR POWER SO DOES THAT MEAN I WOULD BE BETTER OFF BUYING A NEW HEAD THEN I HAD IT APART BEFORE AND THERE ARE TWO BOARDS INSIDE CAN I JUST BY THE ONE BOARD THAT CONTROLS EVEYTHING OR DO NEED TO BUY THE WHOLE HEAD?
Old 10-01-03, 06:01 AM
Joe_F
Kill the caps, no need to shout.
If the assembly is bad, you have to change it as a unit. Not serviceable.
Old 10-01-03, 07:42 AM
ohioman31
joe
ok thanks i probably have to change it then and sorry about the caps thanks for the help
Old 10-01-03, 12:17 PM
Joe_F
Another option:
I BELIEVE there might be companies that remanufacture and test these. Check with any good auto parts store that handles remanufactured electronics and see if they can call their supplier and ask.
Old 10-01-03, 06:31 PM
mike from nj
or head to the salvage yard---might be cheapest
Old 10-01-03, 06:50 PM
darrell McCoy
Joe is right on, there are places that will check and repair these for about 100 smazolias plus 12 mo warranty. If you cant get results from parts place, try dealer and if all else fails do a search for automotive electronic climate control head repairing.
