Ac/heating
Old 10-01-03, 04:16 PM
MISTYSAV1233
Ac/heating
I HAVE A 1983 CADILLAC THAT ONLY BLOWS COLD AIR ,NO HEAT AT ALL.IT HAS A ELECTRONIC CONTROL. NEW THERMOSTAT & HEATER CONTROL VALVE.WHAT ELSE COULD IT BE?
Old 10-01-03, 05:28 PM
darrell McCoy
electronic climate control head is probably bad. 20 years of use? you are fortunate. These can be removed and checked/repaired for about 100 bucks. "If" you could get a new one, you are looking at 3-400 bucks. Plus half an hour labor. Need to find someone who has a wireing schematic, perhaps they can check it out for you. My opinion.
Old 10-01-03, 06:51 PM
mike from nj
is this a beautiful example of a HT4100, gm did their homework when they designed this one. i know every nut and bolt on that engine(sad to say)
make sure that when the engine is warmed up, that both heater hoses are piping hot, feel them with your hand
these atc heads are not the most reliable things, but check the basics first(hot hoses)
Old 10-02-03, 04:13 AM
Joe_F
Agree with all.
(Mike, could also be a diesel or a 4 cyl Cimmaron in 1983. LOL)
When's the last time the vehicle saw a thermostat or any cooling system maintenance? Start here as well.
Old 10-03-03, 06:02 AM
kidsgolf
I agree with Mike from NJ. Check to ensure hoses are BOTH hot. On a 1983 (20 yrs) it is quite possible to have enough sludge in your heater core that hardly any flow goes through, was impressed when I flush out other vehicles on just how much does acummulate! Before getting too deep into expensive controls, ensure good flow. I try every 5 years to change coolant AND flush the lines through the heater core via a garden hose and a copper pipe threaded connection soldered onto a 3/4 inch copper short length of pipe to clamp the heater hose onto; disconnect the other heater hose and run to a bucket. At first you can capture the old antifreez that flushes out, then after it clears take the hose to the ground and open the water flow full to throughly flush it. For good measure I also swap the heater hoses to backflush also.
At least you'll get a good idea of the flow through the core this way, and if still the controls you'll get a lot more heat than you had before out of it!
Wish you luck!
Old 10-03-03, 06:21 AM
Joe_F
Another way is to use a Prestone Flush and Fill Kit and reverse flush. Do this every year and you shouldn't have a problem.
Old 10-03-03, 08:31 AM
mike from nj
kidsgolf----easier than that, i take off both hoses, put a rubber tipped blow-gun on one pipe and an old anti-freeze jug over the other. this way i catch all the chunks and can show the customer what was in there. i found that compressed air is a better cleaner than just a garden hose. this makes cars with marginal to warm heat become HOT.
Old 10-12-03, 03:00 PM
MISTYSAV1233
ac/heating
I want to thank you for all of your help first. I have checked all the hoses and all are hot .i have a mechanic on it he said the new heater control valve that he put on could be bad ,but hes not sure. we will check everything you guys suggested and i'll reply back . Again thank you misty
Old 10-12-03, 06:20 PM
southernwodwkr
also have him check the ac programmer under the passenger side dash hooked to heater/ac box. 9 out of 10 have bad programmers
