Oil Light on Dash
Old 10-04-03, 06:39 AM
ConfusedGuy
Question Oil Light on Dash
Every couple of days, when I pull up to a stop sign or set of lights, the oil light will come on. However, as soon as I start moving again, the light goes off. This is not a daily occurence, and has only happened three times in the past month. I am not due for another oil change for another 2000 kilometres. What is the cause of this, and what can I do to stop it from happening? The last thing I want to happen is to have the car break down in the middle of nowhere, especially as we head toward the winter...
Old 10-04-03, 07:16 AM
darrell McCoy
what type engine, how many miles, engine age?
Could be several things from a clogged pickup screen, failing oil pump, bad main bearings, failing sender unit/guage, on and on.
Old 10-04-03, 07:29 AM
Joe_F
Agree. Need more info.
Old 10-04-03, 10:42 AM
if it is a japanese import....probably the oil pressure sending unit is no good.
If it is a domestic.....probly has excessive oil clearance and the engine will need major work.
Old 10-04-03, 10:45 AM
Joe_F
Lol. Good analysis .
I have seen plenty of GM's blow an oil pressure switch though!
Old 10-04-03, 01:16 PM
ConfusedGuy
The car is a 1999 Chrysler Cirrus, with only 103 000km on it. Oil changes etc. every 5000km as per the manual. The only thing I don't do often enough to it is to wash it.
Old 10-04-03, 03:15 PM
Lugnut's Avatar
First things first. Check the oil level.
Old 10-04-03, 04:24 PM
darrell McCoy
Use a mechanical oil pressure guage. See if the oil pressure is actually low.
Old 10-05-03, 05:36 AM
ConfusedGuy
I have checked the oil level numerous times, and it is fine.
Never seen a mechanical oil pressure gauge before, but I will look into it and try that.
Old 10-05-03, 07:26 AM
darrell McCoy
auto-zone can probably rent you one, not expensive.
Old 10-05-03, 07:44 AM
Joe_F
Autozone rents them free of charge.
Measure the oil pressure with a gauge comparing it to the shop manual's specs. If it's ok, you have a bad oil pressure switch.
If the pressure's out of range, internal engine problems are likely.
