96 Mercury Villager, Blower Motor location ?
Old 10-08-03, 05:13 PM
Z
zop
Unhappy 96 Mercury Villager, Blower Motor location ?
We were driving with the ac on and smelled something burning then it stoped blowing. The heater and defroast do not blow either. I bought a new blower motor hoping this would fix the problem but I cannot find where it is installed. Any help please?
Thanks alot !
Old 10-08-03, 08:51 PM
D
Doug66
i think usually behind the passenger side on the firewall. doug
Old 10-09-03, 06:25 AM
Z
zop
firewall
Thanks d, but It is not there. That is the first place I checked.
If nobody on here knows , I guess I'll have to go spend 15.00 and get a book. darn. haha Thanks anyway.
Old 10-09-03, 07:07 AM
Joe_F
Books are never bad things....
Try using autolibrary.org below
Old 10-09-03, 03:23 PM
Z
zop
Still no blower
Thanks Joe,
Still can't find the blower motor though. Im baffled. I am going to go get the book probably. When I do find it , I will post it for anyone else that has this problem.
Old 10-09-03, 03:26 PM
Joe_F
The motor may not be the problem, could have blown out the blower resistor.....
The simplest way to get the location is to call up the dealer's parts department and ask. That won't help you with the R&R though, a repair manual will.
Old 10-09-03, 04:56 PM
billys68ss's Avatar
According to Alldata there is a trim panel that had to be removed before you can gain access to the blower motor. The blower motor and the resistor are in the same general location, on the right side of the dash on the passenger side.
Here is the procedure exactly as Alldata shows:
1. Disconnect Battery negative cable
2. Remove a plastic rivet and 3 right hand trim panel screws, then remove the trim panel.
3. disconnect the blower motor electrical connector
4. Remove blower motor air vent tubes
5. Remove 3 blower motor screws, then blower motor
6. Remove blower motor fan from motor as required.
7. Reverse procedure to install. Torque righthand instrument panel trim screws to 23-32 inch lbs.
Hope this is helpful to ya,
Billy
Old 10-09-03, 05:02 PM
Z
zop
Smile sounds good
wow, that sounds like thats it. I gotta wait for the wife to get home to try that out. Thanks alot Billy! and everyone else who helped to. I will post the results.
Old 10-10-03, 07:01 PM
Z
zop
Thumbs up Problem solved
Thanks. You found it for me billys68ss!
I didnt even have to remove the trim. Whoever owned the van before us had it off and never out it back on. It is not noticable because its under the dash so its ok. Anyways, I pluged in the new motor and boom, we got heat again. I could see inside of the old motor and it looked burned up. Thanks again for all you kind peoples help.
ZOP
Old 10-10-03, 07:46 PM
billys68ss's Avatar
Glad I could help ya my friend. Thats what I like to do.
Billy
Old 10-11-03, 07:31 PM
Joe_F
Thumbs up
Good job by all. Nice work
