81 Chevette
romod's Avatar
10-10-03, 12:25 AM   #1
81 Chevette
I have an 81 chevette with standard brakes and sometimes they brake and sometimes they don't.When they don't, the brake light will light up. Also it has a big hole rusted through on the drivers side floor,any idea how to fix that?
Joe_F's Avatar
10-10-03, 04:29 AM   #2
Joe_F
The floor has to have a patch panel welded into it to be right. You could rivet in a new panel, but it's likely going to be a short lived repair.
As for the brakes, sounds like hydraulic failure (a leak). Find and repair the cause at once. Dangerous condition.
davo's Avatar
10-10-03, 03:25 PM   #3
check for leaks if you don't find any and the fluid is full you need a master cylinder.
car nut's Avatar
10-10-03, 09:03 PM   #4
Good advice. Since it is intermittent I will bet on a bad master cylinder.
