still no spark
Old 10-12-03, 07:04 AM
D
drillerb
still no spark
I have a 1984 grand prix 5.0 v-8 305, i get no spark I have changed coil pack, dist. cap, rotor, wires, plugs and still no spark and car will not start turns over great, fast spinning engine but will not start. I pulled plug wire and plug and still have no spark. Oh ya carb is getting gas.
Old 10-12-03, 07:39 AM
B
do you have power at the power feed wire going to the distributer this is the large pink wire should have power with ignition on?
does the rotor turn when cranking the engine over if not may have bad timing chain.
Old 10-12-03, 07:46 AM
D
drillerb
no spark
yes the rotor turn and i will go check the power on the pink wire
Old 10-12-03, 05:39 PM
Lugnut's Avatar
Bad ignition control module. If I had a nickle for every spark plug that was purchased to fix a bad ignition control module, I would be rich. (OK, richer)
Old 10-12-03, 05:46 PM
Joe_F
I'd agree on the ignition module OR a broken wire on the pole piece on the distributor.
Both common problems on HEI GM V8's.
Old 10-12-03, 09:33 PM
D
drillerb
no spark
thanks to everyone for the help. It was a broken wire on dist. again thanks for the infoe and hope you all have a great week.
