Fuse for license plate lights on 98 Blazer
Old 10-12-03, 09:32 PM
9
98Blazer
Well, my license plate lights no longer work and the bulbs have been replaced. I'm unsure of which fuse goes to it, and I don't want to pull all of them out to look. Anyone know off hand, or could make a good guess? I have the manual and have found nothing that would indicate which fuse goes with it.
Thanks
Old 10-13-03, 04:18 AM
billys68ss's Avatar
Hey 98Blazer.... Long time no see.
Not likely a fuse as the tag bulbs are run in tandem with the taillights if I remember correctly. If the tail lights work then you most likely have a wiring problem. Trace the wires back to find the problem. Or it could be the socket itself as these take alot of abuse and sometimes burn out.
Hope this is helpful to ya,
Billy
Old 10-13-03, 06:06 AM
Joe_F
I agree. Does this vehicle have any trailer wiring/harnesses aftermarket installed?
Start here if it does. These are often problems. If it was the "cut and splice" type, throw it out. Useless. Only use the factory style plug-ins from LiteMate and other OEM suppliers.
Old 10-13-03, 08:24 AM
T
truckdrivinfool
Since most of the lic. plate lights rely on the ground created by the contact where they meet the bumper or mount a bad ground can also be the problem.
