transmission e350
Old 10-13-03, 04:49 PM
oneblue1
Unhappy transmission e350
my 93 e350 ford transmission leaked very badly on last trip when i crawled under i saw a plastic ring with a rubber seal was on drive shaft coming out of trans would this have caused leak is it that simple?
Old 10-14-03, 04:15 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello: oneblue1
I moved your question into this Automotive forum to ensure you get a reply to the question. The Trucks forum does not have a professional moderator to provide you with an answer.
This Automotive forum does. I am sure the professionals in this forum will have the answer to provide you with the solution.
Old 10-14-03, 06:34 AM
Joe_F
Last time I looked an E350 wasn't a "truck" it was a light truck...
Original poster: Sounds like a rear main seal problem and yes, that will cause problems and leaking like a fountain.
Old 10-14-03, 06:36 AM
darrell McCoy
Most probably. Remove Drive shaft, remove seal and install a new one. Easy, but you should obtain a seal driver for this.
Old 10-14-03, 09:23 PM
Ford by Birth
Lightbulb
yes that sounds like the out put shaft seal. that is the seal at the rear of the tranny. when you get the part if you say rear main seal, you'll get funny looks or get the rear main oil seal for the engine.
