Door panels comig off
snuffs's Avatar
10-15-03, 08:23 PM   #1
Hi, I have 93 saturn sl2. After 10 years just about all my door panels are seperating from the metal frames? I've tried silicone sealer and it seems to work fine on some doors after the curing of the silicone and removal of the clamps. Trouble is some fasters come out with the panels after the process. Does anyone know a better way this? better sealant, different metod,etc. Thanks snuffs
cheapfurcoat's Avatar
10-15-03, 09:37 PM   #2
cheapfurcoat
Those fasteners can be had relatively cheaply from your local auto glass shop.
If the new ones won't stay in the panel, go to a hobby shop and get a large bottle of thick CA adhesive (super glue) and a bottle of grip kicker.
That stuff never failed me in all the years I did auto glass and trim work.
mike from nj's Avatar
10-15-03, 11:15 PM   #3
mike from nj
do you mean the whole panel is coming away from the door frame, or the fabric is peeling off the panel itself.
for a whole panel that won't stay stuck, like when the clip mounts are broke off the back, i put a strategically placed sheet metal screw, then a little touch-up paint or just a black magic marker to darken it. make sure it doesn't go too far into the door or it might interfere with the glass
works for me (on my older stuff)
Joe_F's Avatar
10-16-03, 07:51 AM   #4
Joe_F
I agree with Mike. What is the actual problem/detail of what's coming apart?
My mother drives that same vehicle and I cannot place what you're talking about.
snuffs's Avatar
10-16-03, 01:05 PM   #5
a Picture is worth a thousand words, they have one at [URL=http://]www.cybrrpartspro.com for saturn sl2 93 search.
It's called the interior trim panel. the trim panel is coming loose from the door assembly. thanks for the tips snuffs
Joe_F's Avatar
10-17-03, 05:54 AM   #6
Joe_F
As noted, make sure the clips are secure and all there. Should be fine.
snuffs's Avatar
10-17-03, 02:44 PM   #7
Thanks Joe cool, it was at your web site, I foung all needed info I should gave all. thanks again, snuffs
Joe_F's Avatar
10-18-03, 08:11 PM   #8
Joe_F
Good job.
