engine wont turn but will crank
Old 10-17-03, 03:52 PM
raidersftball
i have a 97 gmc suburban the engine will crank but wont turn over added gas to the fuel inj. (carb.) and it almost turned. do i have a vapor lock?
Old 10-17-03, 04:05 PM
darrell McCoy
Can you hear the fuel pump running. Check the fuel pressure.
Old 10-17-03, 07:09 PM
Desi501's Avatar
Vapor lock unlikely
Sounds pretty likely you have a fuel related problem. Fuel pumps are pretty common. Cycle the key on and off while someone listens for the pump at the tank. It will only run for a few seconds on each key cycle.
Old 10-18-03, 08:31 AM
take a rubber mallet and rap the underside of the fuel tank while somebody cranks the engine. this might get the fuel pump to run...
Old 10-18-03, 07:47 PM
Joe_F
Arrow
I agree with BG.
Trackbacks are On
Pingbacks are On
Refbacks are On
