Daytime running lights
Old 10-19-03, 08:22 PM
bmcclin
My 1998 Chevy Malibu, 3.1 L, 75000 miles, Daytime running lights (DRL) stopped working. I have checked all the associated fuses and relays. All check out OK. The headlights are Working OK, no other electrical problems. Any help will be greatly appreciated.
Old 10-19-03, 11:34 PM
mike from nj
the e-brake isn't 'slightly' stuck on, is it?
try cycling the pedal up and down a few times to reset the switch
Old 10-20-03, 11:06 AM
bmcclin
Nope, the e brake it isn't stuck, tried that, no luck.
Thanks for the try.
Old 10-20-03, 02:48 PM
You need to find out if you have any codes in the body control module.I don't think Autozone is going to be able to pull those codes.Any current codes need repaired before you continue with diagnosing the drl's.I would check all fuses not just headlamp or drl fuses.If you get bcm codes and need help let us know,we can go from there.
