Nissan Quest window switch broken
Old 10-23-03, 03:26 PM
Tenpac
Plastic switch cover came off in my hand with the window down.
Need help on how to remove door panel and switch.
Old 10-23-03, 04:30 PM
Joe_F
Helps to know the year of the Quest......
If autolibrary.org below has nothing, hit your local dealer's parts counter for an exploded view of the door panel. That should get you started.
Old 10-23-03, 06:27 PM
darrell McCoy
I am not sure about a "quest" however, look close as a lot of newer veh, the switch comes out from the outside without removal of panel. May come out as an assembly. Usually no screws involved, just snaps out. Worth a good look before you start removing to much.
