fuel problem
Old 10-25-03, 05:45 AM
hawaiian
fuel problem
i've replaced the fuel pump and now the car still will not stay on.I've turn the key and the car starts then turns off. the only way the car stays on is if I turn the key and hold it all the way to the right. what can I do my car is an aucra legend(1993) Please help i'm lost.
Old 10-25-03, 08:02 AM
Desi501's Avatar
Sounds like a bad ignition switch.
the_tow_guy's Avatar
Received 177 Upvotes on 139 Posts
For starters, was the fuel pump diagnosed as bad or was it replaced as a guess to fix the problem? Joe Cool will be along to ask you if you've been through his "Basics", so that would be a good place to start.
Old 10-25-03, 09:00 AM
hawaiian
yes the fuel pump was the problem.now i can't understand why the car still has problems staying started.
Old 10-25-03, 10:22 AM
darrell McCoy
Check your wires, sounds like you have gotten them mixed at on the pump.
Old 10-25-03, 02:14 PM
hawaiian
Question fuel pump
I was lucky enough to get the car started and drove it home. When I got home the car was running just fine,until i turn the key off.The car will not start again unless I hold the ignition key all the way on.
Old 10-25-03, 02:17 PM
Joe_F
Sounds like a worn out/out of adjustment lock/switch assembly.
Old 10-25-03, 02:20 PM
hawaiian
would that cause the car to shut off and only run when the key is turn all the way to the right and held there?
Old 10-25-03, 05:46 PM
Desi501's Avatar
Yes, definately. Both positions of the switch have individual outputs for running power and one of them is not supplying power. It's not that uncommon in Jap cars. Do you have dash lights and accessory power when key is turned to the "on" not the start position?
Old 10-26-03, 04:35 AM
hawaiian
Unhappy
yes i do if i hold the key back to the left a little the car stays runnning but the the key will not stay in the correct postion.
Old 10-26-03, 02:44 PM
Joe_F
Sounds like a bad switch, yes.
