ignition switch
Old 10-25-03, 09:57 AM
hawaiian
Unhappy ignition switch
I've replaced my fuel pump and now the car will only stay on when the key is turned all the way to the right ,is this a bad ignition switch or something eles?
Old 10-25-03, 12:23 PM
Desi501's Avatar
Is it actually running in the start position or just trying to start? Can you throttle it up while holding the key?
Old 10-25-03, 02:10 PM
hawaiian
Question
yes by holding the key the motor starys running . I was able to get the car running and drove home. I then wanted to see if the car would start again and the same problem ll exisit.
Old 10-25-03, 02:15 PM
Joe_F
And the type of car is?
Old 10-25-03, 02:22 PM
hawaiian
1993 acura legend
Old 10-25-03, 03:59 PM
Desi501's Avatar
Yep, sounds like an ignition switch problem.
Old 10-26-03, 04:39 AM
hawaiian
Unhappy
do you know any way to change the ignition switch because i've looked at the switch and it has at least 5 flat bolts. should I drill the bolts out like the repair book said too,or is there a easyer way of repairing this problem?
Old 10-26-03, 09:11 AM
Desi501's Avatar
They most likely are "tamper proof" bolts with breakaway heads. They are tough. You may have to tap them around with a small punch or chisel. try to catch it on the edge and tap it in a turning direction. Remember, your not changing the lock cylinder, just the electrical portion.
Old 10-26-03, 02:37 PM
Joe_F
Arrow
On many Japanese vehicles like this, the electrical and mechanical switches tend to be one part. Get the replacement part first so you know what you will be changing.
