Ranger 92 Water Pump
Old 10-26-03, 03:27 PM
nhouston
I am trying to replace the water pump on a Ford Ranger 92, 3.0L. One of the bolts on the water pump requires that the A/C support bracket be removed. The problem is I can find all the bolts to remove the bracket. I have removed two bolts from the front (one of which is hidden) and two from the side in the rear. The bracket is still being held tight by something that I can't find. I have seen numerous other posts on other sites from others with same problem but no one has offered an answer yet. Can anyone help?
Old 10-27-03, 04:19 AM
Joe_F
As I tell everyone else....
Have you checked autolibrary.org below or a good shop manual??
Old 10-27-03, 04:18 PM
nhouston
I tried the site you suggested before I ever made my post. It wasn't any hlep. Other shop manuals just say to remove the bracket but don't tell you how. If it doesn't give you details you would think it was obvious but not in this case.
