Honda Accord Clutch Adj.
Old 10-27-03, 08:15 AM
kianje
1993 Honda Accord- Recently I was hunting my main relay and had to remove the clutch adjustment (don't know what it's called) above my clutch pedal to get to the relay. Since I put it back in, I have had it back out trying to get my clutch properly adjusted. It has now been a month and I noticed yesterday when I accelerated a little heavy, I felt the clutch slipping. Now I have forgotten which way I adjusted the twist nut on this device. Because I don't want to use the trial and error method if possible, which way should I adjust the nut, tighten or loosen? Any extra advice will be appreciated.
Thanks
Old 10-27-03, 08:55 AM
Joe_F
Check autolibrary.org to see if they have the adjustment procedure.
Trackbacks are On
Pingbacks are On
Refbacks are On
