90 honda accord
Old 10-27-03, 09:45 PM
jcondon
90 honda accord
I have a fuel injected 1990 honda accord automatic transmission. here's the problem. when its below 50 , the car starts and idles rough. I have to keep the accelerator pressed to keep it running. If it remains running and i turn the wheel the car will die. The exhaust smoke is very white. As soon as the car has run for more than three minutes the problem goes away until I try to restart it a couple hours later.
Old 10-28-03, 07:08 AM
Joe_F
Start with my "The Basics" post below.
Old 10-30-03, 02:17 AM
fatcatdj
Never had the injectors replaced ?
Old 10-30-03, 05:59 AM
jcondon
no I have not, but it idles and runs fine after a couple of minutes. I did notice something. If the tank is at least half full, I do not have this problem at all. Could it be the fuel pressure regulator or moisture getting into the system
Old 10-30-03, 06:33 AM
Joe_F
Cat:
Keihin injectors as used in this Honda are VERY reliable. The problem is not likely here.
Original poster: Again, you must start with the basics as I have them outlined. Answer some of those questions and let's go from there.
