fule filter
bowlingpro2501's Avatar
10-28-03, 12:35 AM   #1
bowlingpro2501
fule filter
Hay guys. I have a question. over the weekend me and my dad tryed to change my trucks fule filter(79 gmc c1500 with the 350 4bbl) and in the manual it said it had an in line filter but we cant find it. then we noticed that in the book it talks about Rodchester carbs and then I noticed that I have a Holly carb. So we then we thought that the filter was inside the carb so we tryed to take a part the chamber where the fule line goes into the carb and we couldent move the nut at all. could the filter be somewhere else? if it is inside the carb how do we get it out? if you need anymore info let me know and I will try to get it for you. Thank you again guys.. Matt
bigguy05641's Avatar
10-28-03, 05:32 AM   #2
The original set up with the Rochester carb had a fuel filter screwed into the float bowl. The location of the filter at this point is where they put in when they put the Holly on.
Bad decision, by the way......but that's just me...
Joe_F's Avatar
10-28-03, 07:00 AM   #3
Joe_F
I'd agree the Holley was a bad choice here as it will never run 100% compared to even a stock Q-jet for that truck.
I'd be shopping for a Q-jet for it. Hit some junkyards, should be able to find the right one very easily.
Depends on which Holley you have as to what was done with the fuel filter.
10-28-03, 01:43 PM   #4
bowlingpro2501
ok, how do I find out what type of Holly I have? any numbers I can give you? I do not know cause I did not put the carb on in the first place. And about the Q-jet do I look for one of the same year? And I will add that to the list of things to do. Right now the holly is geting the job done. and cause I have no money I cant do anything with the carb at this moment. What benifents will I get to swiching to the Q-jet? Thanks for your help guys, have a good day.
YamahaWolverine's Avatar
10-28-03, 02:22 PM   #5
It's Fuel not Fule, And just put a universal inline filter between the fuel pump outlet and the carb inlet.
Joe_F's Avatar
10-28-03, 04:35 PM   #6
Joe_F
On the air horn, there is a four digit # in most cases. If you e-mail Holley or call them, they can help identify it.
Advantages of a Q-jet:
Idle
Power
Driveability
Looks
Fuel Economy
Ease of hookup
Emission control
Originality
Correctness
etc, etc, etc. etc. Far superior in every way. Go to any GM dealer that has a copy of the 79-84 C,K Series GM parts book (all will) and ask them what stamping #s were right for your vehicle. Take a copy of that and look for trucks with that # on the carburetor in th junkyard.
You can also try www.junkyarddog.com to locate one as well.
KurtDixon's Avatar
10-28-03, 04:56 PM   #7
KurtDixon
I am pretty sure it was just a typo and he kind of has to find the old filter anyway even if he was adding a universal so he could remove it (I don't see the point to adding a universal anyway.)
10-28-03, 06:49 PM   #8
A typo 3 times? OK. And since this didn't utilize an internal filter a universal filter will do just fine.
KurtDixon's Avatar
10-28-03, 07:47 PM   #9
KurtDixon
Oh, I guess he did spell it wrong, and uhhhhh....what's your point.......
10-28-03, 07:59 PM   #10
bowlingpro2501
Ok first off sorry for my poor spelling. I dident think it would be that big of a deal. And I did think about puting on a FUEL!! filter on but I thought that the old one still needed to be changed cause of all of the junk thats in that filter.
And thank you Joe again for your help. I will get the number as soon as I can. and when I get the other stuff done on the truck that are more importan I will get the correct carb and mabe thats why it is hard for me to start the truck when it is so cold. it just seems like it is starveing of gas and offen times just shuts off after a few sec of running or it runs so rough that if I touch the gas it quits... thanks again guys for your help............ oh my canopy rubs on the cab is there a way to make it quiet or not rub? mabe puting some kind of tape or something. I cant back it off cause there is no room to do so. thank you again.... matt
KurtDixon's Avatar
10-28-03, 08:04 PM   #11
KurtDixon
LOL don't worry about it, I think a few people are a little "cough, cough" uptight... Let's relax If the fuelfilter is clogged, either change it or change it and add a universal, either way you needed to know where it is, it sounds like you now know?
10-29-03, 02:09 AM   #12
Not uptight at all buddy, but atleast he knows how to spell fuel now.
Joe_F's Avatar
10-29-03, 03:59 AM   #13
Joe_F
Pro:
Hit a camper or RV shop. They should have some sort of insulating tape you can use for this purpose.
Yes, Holleys can be a pain to start cold. Another advantage of a Rochester (automatic choke ).
10-29-03, 04:11 AM   #14
bowlingpro2501
If the Q-Jet are so good then I wonder what posessed the previous owner/s to put on the holley then?!? It sees a bit weird. But anyway thats just another thing to get done on the truck. But I still love it. shes worth the money I think. How much do you think a Q-jet might set me back? How do I know if it is in working order? How do I make sure that I pick a good carb if I go to a junk yard? And thanks guys for your great survice here ... thanks again Joe...... Matt
Joe_F's Avatar
10-29-03, 04:16 AM   #15
Joe_F
Because they thought they would "go faster" with a Holley .
Bottom line: For a street application, and most strip/street, etc combinations, a Rochester is far superior.
As for if the carburetor you get it is good, make sure it's complete, not rusty and not full of water. Don't take it off of a vehicle where the hood is missing on the truck----good chance it's taken on some rain
Each yard is different for what they will charge for parts. I'd say around 25 to 35 bones for a rebuildable Rochester is reasonable. Have it done professionally & set up by someone good with carburetors if you lack the appropriate shop manual, tools and knowledge to do it yourself.
The vehicle is worth fixing to you because you like it--that's the main thing .
10-29-03, 04:22 AM   #16
bowlingpro2501
WOW joe that was quick, you must be a fast typer . thanks again. Is it hard to put on a carb? I am sure that if I can ever find the good manuals you talk about it might make it easyer. I amagin that there is a bit more to it then just takeing off the old one and bolting on the new one. and yes your right about the truck . it is my first and I love it lol
Joe_F's Avatar
10-29-03, 09:12 AM   #17
Joe_F
Depends on your ability, time and access to tools, etc.
Adjusting and setting these up can be tricky if you're not in the know about it. A good old time shop shouldn't charge much to rebuild it and set it up properly for you
