95 Mercury Mystique
Old 10-28-03, 04:13 PM
95 Mercury Mystique
95 Mercury Mystique 4 cyl. W hen I drive 40 mph. or in stop and go traffic car overheats, when I start driving over 60 mph. the car goes back to normal. I stoped to check the anti-freeze level and was low I opend the cap and all the fluid rushed back to the container.
Old 10-28-03, 04:17 PM
Joe_F
Sounds like the cooling system hasn't seen attention in a long time.
Dump the coolant, flush and fill it with new and change the thermosat. See where that nets you.
Old 10-29-03, 04:43 AM
hogfan's Avatar
Check the cooling fan (electric)?
Old 10-29-03, 02:45 PM
Thanks Joe_F and Hogfan. I took your advice Joe_F and change the stat and flush and fill, the needle on the gauge stays on the a and l, after a few minutes the fan kicks on and stays on for about 45 seconds is this standard procedure.
Old 10-30-03, 06:46 AM
Joe_F
Did you bleed the cooling system? What does your shop manual have to say about the bleeding?
Old 10-30-03, 07:44 AM
Flush and fill is not bleeding the system?
Old 10-30-03, 08:01 AM
Joe_F
Nope. See autolibrary or a shop manual for how to bleed (if applicable).
Old 10-30-03, 03:02 PM
Bleeding n/a.
