Turn Signals not working 97 Blazer
sdunn's Avatar
10-29-03, 04:47 AM   #1
sdunn
I have a 97 Blazer the turn signals are not working. The lights on the dash do not light up when signal is turned on. When I turn the flashers on all lights work. I checked the fuse it looks fine, but I replaced it anyway. Can you help ???
Joe_F's Avatar
10-29-03, 09:10 AM   #2
Joe_F
Bad turn signal flasher in all likelihood. Call the dealer and find the location. Replace it and should be good to go.
fatcatdj's Avatar
10-30-03, 02:38 AM   #3
fatcatdj
also check/change the bulbs on your wreck
dual filament blinkys are deceiving.
The Yankees ===$$$$====losers
Joe_F's Avatar
10-30-03, 06:35 AM   #4
Joe_F
Cat:
I'd normally agree, but correctly working flashers usually indicates a turn signal flasher issue.
