1993 Dodge Caravan
wingplow's Avatar
10-30-03, 02:06 PM   #1
wingplow
1993 Dodge Caravan
Can anybody tell me what size are the three gas lines that go from the front of the van to the gas tank.
Thanks
Desi501's Avatar
10-30-03, 04:10 PM   #2
They can vary but the feed line is usually 3/8 the return is usually 5/16 and the vent can be anything.
Joe_F's Avatar
10-31-03, 03:55 AM   #3
Joe_F
What are you trying to accomplish?
mike from nj's Avatar
11-01-03, 11:38 PM   #4
mike from nj
most ones i've seen had 5/16" as the pressure line, 1/4" as the return and small, maybe 3/16" for the vapor line.
if you're going to be doing any replacing with rubber hose, use ONLY high pressure "EFI" rated('efi' stamped right on the side) hose, this will have an additional barrier inside for the high pressure. plus there are special high pressure clamps just for this application, and they're not the 69 cents 'worm' type clamps that you get in pep boys or autozone, even though they tell you they will work.
either part will work for a little while, but you might be smelling gas before not too long, or the regular type hose might just burst when you least expect it.
just so you know
