car idling weird
Old 10-31-03, 01:29 PM
car idling weird
1) 1995, honda accord LX 2.2 (non-vtec)
2) The problem is the car idles around 1700-2000 rpm on startup and until i usually shift into 4th gear and then it calms down to idle at about 700 rpm.
3) just last weekend I tuned the car up- since it was about that time and i thought it might help the idle issue. here is what i replaced:
-spark plugs
-spark plug wires
-oil and filter
-air filter
-pcv
I will be changing the tranny fluid and radiator this weekend to ready it for winter.
Any ideas on the idle?
Thanks.
Charlie
Old 11-02-03, 06:21 AM
Joe_F
Check for any vacuum leaks, clean your throttle body and inspect the idle air control valve for proper operation.
Start here...
