Lubrication of nylon bushings
grandspan's Avatar
NY
10-31-03, 09:27 PM   #1
What is the proper lubricant for steel shafts roating on nylon bushings? I am restoring an old VW Beetle (1974) and rebuilding the windshield wiper system trans.
There appeared to be grease on it, but it was filthy. I'm wondering if I should use Lubriplate White, or possibly the newer non-melting silicone grease made for use on disk brake slides, since once the unit is installed in the car it won't be lubed again for years unless there's a problem. Thanks for your help.
darrell McCoy's Avatar
11-01-03, 07:55 AM   #2
darrell McCoy
aerosol white lithium will probably work as well as any.
Joe_F's Avatar
11-02-03, 05:48 AM   #3
Joe_F
Neither one should be an issue or a problem. Gunk it/degrease it to get all the old crud off and then lube it up sparingly. Doesn't need a lot to work well.
