1999 Ford Expedition dies
Old 11-02-03, 01:35 PM
Biobus
My 1999 Ford Expedition (5.4L) keeps dying when I start it. It starts, then dies quickly unless I rev up the engine. As soon as I quit giving it gas, it dies. I am able to give it gas, then quickly put in gear to drive, but it did die last night as I was turning into the driveway. Anyone know what might be the problem?
Thanks,
Steve
Old 11-02-03, 11:55 PM
start by having codes read autozone can likely retrieve codes for you so can most shops.
check for vacum leaks a large vacum leak could cause this problem check the vacum line near the back of the intake common place to develop a leak, could also be an idle air control valve problem also.
Old 11-03-03, 05:43 AM
Joe_F
Thumbs up
I agree.
Old 11-03-03, 11:21 AM
Biobus
Had to take it into the shop, as wife was needing it faster than I could get it done. The mechanic ran the diagnostics and tells me the idle control motor needs to be replaced, which seems to be inline with your thoughts. ($180 for parts & labor)
Thanks for the help.
Steve
Old 11-03-03, 11:23 AM
Joe_F
Let us know the outcome.
Old 11-04-03, 07:21 AM
that must be a common problem with that year model. our 99 did the same thing, but it was off and on. not a continuous problem. we traded it in before finding the problem. i personally did not like the sensitive steering. i thought it was unsafe. other than that, it was a great car.
Old 11-05-03, 05:30 PM
Biobus
Replaced the Idle Control Motor and everything is working great.
Old 11-05-03, 05:49 PM
helpful
Re: 1999 Ford Expedition dies
Thanks,
Steve
------ Yes, The problem is your fuel filter, Change that first, it's gone bad
Old 11-05-03, 05:54 PM
Biobus
didn't need to change the fuel filter, it was the idle control motor
Old 11-06-03, 08:22 AM
Joe_F
Help:
How do you know it's the fuel filter?
