Hood Release 98 Blazer
Old 11-05-03, 05:40 PM
9
98Blazer
Hey, I have a 98 blazer and the hood release has a hard time releasing the hood. At first I thought the cable was frayed so I took it to the dealer because I didn't want to deal with it. They said that it was just sticky and they sprayed it with White Lithium I presume. Well a month or two later and it's stuck again, I sprayed it but it's kind of gummy now. Worse, it'll open but then I can't shut it. The latch is really gummed up. What is the proper way to clean this, and lubricate it?
Thanks
98Blazer
Old 11-05-03, 06:22 PM
D
darrell McCoy
aerosol white lithium is as good as any. Get you some rags so you dont make a mess, either use brake clean or PB blaster and it should clean up. Also grease the hood pin some. I clean and lube mine 2 or 3 times a year whether it needs it or not. Same with door latchs and anything else that moves. A frequently neglected item on a veh.
Old 11-06-03, 07:18 AM
Joe_F
Agree with Darrell. Lubriplate usually works fine. See what the owner's manual wants. There is usually a what to lubricate what component chart in most books.
