11-06-03, 12:13 PM
DEXTERDOG
Can someone tell me what to check next? The turn signals on a 1987 Honda Accord aren't working. I have replaced the fuse and two faulty bulbs and nothing happens when I use the turn signal. No lights, no clicking, no nothing. HELP!
11-06-03, 12:16 PM
Joe_F
Do the hazards work OK? If they do, bad flasher/turn signal relay more than likely.
11-06-03, 12:37 PM
DEXTERDOG
TURN SIGNALS
I just checked and the hazards don't work either. Tell me it's not something electrical.
11-06-03, 12:52 PM
Joe_F
Assuming the grounds throughout the system are good, you may have a bad turn signal switch.
11-06-03, 10:38 PM
mike from nj
i would be thinking more along the lines of a bad blinker/flasher relay. most jap cars only use one for both turn signals and hazards.
if the hazards worked, then i would say the flasher would be ok.
since your hazards don't work, i'd be looking at a wiring diagram to confirm that your particular car only has ONE flasher serving a dual function( turn signals and hazards)
(opposite to most american cars)
