97 Dodge Dakota
Old 11-07-03, 06:28 AM
Dakota97
Angry 97 Dodge Dakota
My 97 Dodge Dakota is making a faint thumping noise when I'm driving, it becomes more apparent when I'm coming to a stop, and occasionally it seems to go away altogether. What can it be?
Old 11-07-03, 06:44 AM
Joe_F
A lot of things. Start with looking up some bulletins (if there are any) at alldata.com
Old 11-07-03, 08:37 PM
mike from nj
does the noise change, start, or go away when hitting the brake pedal?
how long have the front tires been on the front?
4wd, 2wd?
Old 11-08-03, 04:40 AM
Dakota97
4wd, 2wd?
The noise is very faint while driving, it increases (gets heavier) when I hit the brakes.
The tires have been on front for about 11 months.
Its a 2wd.
Old 11-08-03, 09:45 PM
mike from nj
it could be a bunch of things, like a slight tire noise, as they should be rotated every other oil change or 6-7,000 miles, whichever comes first. this evens out the wear and keeps noise to a minimum.
if you have any noise when hitting the brake pedal, you pretty much narrowed it down to the brakes. they might not necessarily be bad, but they should be looked at by a knowledgable eye, whether that is you or not depends on your level of knowledge. there could be a simple rust ridge on the edge of the rotors, or there could be a broken half of a pad left, with it about to fall off, i wouldn't want to be in front of you when that happens.
there was an issue with the front wheel bearings (on 2wd ) making noises, but the ones i've seen were extremely noisy, and had no affect from the brake pedal.
fyi
Old 11-09-03, 01:14 PM
Joe_F
Have you pulled off the wheel and had a look?
