92 Ford E150, 114 and 116 trouble codes
Old 11-09-03, 01:26 AM
T
I have a Ford Van with 302. The check engine light comes on intermittantly. I checked the engine codes KOEO with a jumper wire. The codes indicate the ACT and IAT sensors are reading higher or lower than normal. I checked the sensors and they both read 63.8k ohms with a cold engine at 47deg ambient temperature. That is pretty close to what the chart says it should be. The resistances dropped normally after I warmed up the engine. What should I do now? Should I change the sensors even though they test good?
Thanks,
tgood
Old 11-09-03, 10:23 AM
billys68ss's Avatar
First thing.... what year is the Ford Van? Next thing, are there any runability or drivability problems? Does it give you any problems when it is cold or hot or any time at all? If not then just clear the codes and drive. If the codes come back then you might have a issue with one of the sensors. Fords are notorious for setting ghost codes and having mile long diagnostic processes for what seems to be the simplest codes, and then it is something totally seemingly unrelated.
Hope this is helpful to ya,
Billy
Old 11-09-03, 12:43 PM
Joe_F
Thumbs up
I'd agree with that.
Old 11-09-03, 01:01 PM
billys68ss's Avatar
One more thing...... What is an ACT? The 116 code refers to the ENGINE COOLANT TEMPERATURE being higher or lower than expected, and the 114 code refers to the INTAKE AIR TEMPERATURE being higher or lower than expected. The IAC has nothing to do with temperature. There is a temp sensor in the air filter housing and that may be your culprit, but again what are the symptoms if any you are noticing?
Billy
Old 11-09-03, 01:24 PM
Joe_F
Maybe you mean ECT?
Old 11-09-03, 10:28 PM
T
The van is a 1992. Sorry about the typo, I meant ECT. Driveability is okay. I did blow a heater hose a couple of months ago. So now I'm thinking these are just some lingering codes from that. I'll clear them and see what happens.
Thanks,
tgood
