Starter problems
Old 11-09-03, 02:19 AM
Abe Lincoln
Starter problems
1974 Lincoln Continental, installed new starter and starter-relay, when i put voltage to the battery, the starter instantly turns over until i disconnect the battery. what wire would cause a direct voltage to the starter from the battery. Question: does the hot lead from the battery and the wireharness connection attach to the same side of the starter relay???
Old 11-09-03, 07:29 AM
the positive cable from the battery goes to one side of the solenoid with the wire harness connections, the other side of the solenoid has the cable leading to the starter. the small wire terminal that energizes the solenoid usually push on or could be bolt on the solenoid terminal comes from the ignition switch.
Old 11-09-03, 12:55 PM
Joe_F
What was the original problem?
Trackbacks are On
Pingbacks are On
Refbacks are On
