Hyundai problems with not starting after oil change
Old 11-09-03, 06:46 AM
mesh30
> I have a 91 Hyundai Scoupe, The front of the car was on car ramps. Car
was
> started then shut off. Changed the oil and filter, went to restart car,
car
> will not start now. Have checked spark, ok, then checked fuel before and
> after filter, same pressure, but not getting gas into the cylinders. Any
> idea of what could be wrong? Had no problems with starting prior to this
oil
> change. Heard there maybe a shut off for the fuel. Can hear the fuel pump running, but not getting gas.
Old 11-09-03, 12:59 PM
Joe_F
What were the readings on the fuel pressure gauge when you checked fuel pressure????
Old 11-10-03, 04:14 AM
mesh30
I don't have a fuel pressure gauge. Took off the hose, one at a time before and after the fuel filter and cranked the key.
Old 11-10-03, 05:41 AM
Joe_F
Thumbs down
Won't tell you anything on a fuel injected car. Rent a pressure gauge from Autozone and tell us what you find.
