11-10-03, 04:04 PM
supertrucker
How hard is it for a regular joe to replace ecm on 91 LeSabre?
11-10-03, 05:12 PM
it really isnt very hard to replace just remove old ecm remove prom and install prom in new ecm and reinstall, should probably have battery disconnected when doing this.
exactly why are you replacing it?
check the link below may have more info on location and removal and install.
http://doityourself.com/to/cybrrparts.htm
11-11-03, 06:36 AM
Joe_F
What is the actual problem with the vehicle? ECM's do not usually go bad.
11-11-03, 05:53 PM
mike from nj
in my very limited experience of older GMs, i've seen a few go bad, and a remanufactured can usually be had for under $150 depending on the application.
fyi
fyi
