lack of fuel each morning at the carb
Old 11-15-03, 05:18 AM
stilllearning6
1988 YJ Jeep Wrangler 258 with BBD -
It appears as if there is a lack of fuel each morning in the carb --as I am not seeing the priming squirts of fuel down the venturi as I depress the pedal .
After exactly 4 attempts to start each AM , I can get fuel at the venturi , the Jeep fires up instantly , and runs fine all day . Plenty of fuel delivery .
When the Jeep stands for an extended time , the jeep requires the 4 attempts to start. It appears as if the fuel needs to be replenished in the carb fuel bowl . Once the cranking has occurred , plenty of fuel .
Is the fuel reversing direction and emptying backward from the fuel bowl to move upstream back through the fuel filter and into the fuel pump ? Is this possible ? Is there a vacuum created upstream of the carb that would suck the fuel out of the fuel bowl ? Are there one-way check valves in the system to prevent this ?
Old 11-15-03, 05:59 AM
It sounds like the fuel bowl is draining. I know the plugs at the bottom of the venturi can leak. If they do I seal them up with JB weld. Make sure the carb isn't loose from the base either.
