Mechanical Speedometer Jitter
I've got a '91 Toyota 4X4 Pickup with 148k miles. The speedo has started to periodically become extremely "nervous" at around 45mph. The dial will be steady at the indicated speed for a while then it will start jumping between 40-50 (assuming an actual speed of 45mph). Is this usually a problem with the cable (lubrication etc.) or the speedometer mechanism? If it is a a lubrication issue, is there any way for me to lube it from the bottom end (at the tranny) vs having to take the dash apart to get to the top of the cable?.. If it's a relatively easy fix, I'd like to take care of it, but since I got laid off from work last week, there isn't going to be any non-DIY work done on this for while.... :-<
Thanks in advance,
Dave Frandin
dave-AT-frandinDOTohArrGee
Thanks in advance,
Dave Frandin
Received 0 Votes
With that mileage I would remove and clean the cable and lube it.Best best would be to replace it,it may be worn into the casing.Toyotaman will be here and may have other suggestions as well.
it's been a while since i've seen a speedo cable. the ones i used to work on (not toyota) after the dash cluster came out, you could just pull the center 'driving' cable out of the sheathing, clean it real good, then there is an actual cable lube for it, and slide it back into the cable(all the way to the trans) all from inside the car.
Received 0 Votes
Lube
I am with these guys go buy some cable lube remove cable clean real well lube and reinstall.
I dont think it is too hard to remove from the dash Toyota is a pretty simple design,
But make sure you use the correct lube made for spedos not any old lube you have laying around.
